Radios...
All knackered when I got them, all bar one now working to the extent I can get bits to fix them.
Two mighty Grundig Concert Boy 1100 sets. Sound fabulous! The black one works fully, the brown version (bought new by my Dad to take to Africa) needs a fair bit more work on the AM side.
Two versions of the Sony ICF-35. Black one is more or less fully working and cosmetically OK, silver one has suffered catastrophic battery leakage at some point in its life, and only runs on an external adapter, an original model of which I fortunately have. It also, like the brown Grundig, only works on FM, but sounds OK.
Sony ICF-SW7600 digital PLL receiver. This one needs a load of surface-mount capacitors replacing, due to a manufacturing error by Sony.
The production fault was to flow-solder them too hot, and the capacitors started to deteriorate from that moment on, usually conking out after about 15 years. If (very carefully) replaced with ceramics, the radio should last virtually for ever.
When working correctly, they are one of the best small shortwave sets you can buy, even today. I previously had an ICF7600DS, which I gave to my younger son when I got a new ICF-SW7600GR, the last model in the line, in 2003. That will probably work for decades, as all the bugs had been worked out over the preceding 20 years. It's my totally overkill alarm radio!
I like radios!
