Andy in Germany
- Rottenburg am Neckar
I think Brasso has amonia in it . A bit like T Cut .
So does pee, so if you're really going for that self-sufficiency vibe there's a ready supply.
You can but those gor manynhops and ovens, not too expensive.I should get you to create a replacement control knob for my gas hob - I broke one of its plastic knobs by dropping a tin of beans on it!![]()
I haven't found exactly the right one yet, but similar ones found so far are what I would describe as EXTREMELY expensive - £9.50 - £15+ for just one plastic knob!You can but those gor manynhops and ovens, not too expensive.
I tracked it down!If I can find the broken knob***, I might go back to plan A - epoxy something inside to replace the broken collar.
I binned the body of the vacuum cleaner. My wife didn't think it was very good . It seemed a shame to get rid of electric motor which could be used for something else .Please report back on your fixing of the vacuum cleaner.
fair point. It's the "subscription model" being frantically pursued by many companies producing all sorts of stuff. And there has long been more easy profit in the "knowledge economy". ie - they retain the knowledge and you can't fix it yourself.I've often thought the main reason cycle companies are going for Ebikes is because they've realised a well maintained regular bike can last forever, and the replacement parts can be bought anywhere: Ebike parts can be much better controlled and made more bike-specific.
Thanks. I will peer at the small print to see what those captivating childhood whiffs may have been. Will wait until the rain stops as I seem to remember from nervously approaching the tin when I bought it that any close-up work with it should be done outside/not in an enclosed space. Will report back if the trees wilt.I think Brasso has amonia in it . A bit like T Cut .
Working in a German City Farm was a similar experience, but with better engineered baler twine.
What with having a German farm trainee right now, the perennial joke atm, is that if some piece of kit is working well, it must perforce, have been engineered by Germans* -
- I'm sure given another 9 months, or so this might cease to be quite so hilarious.
*On closer inspection, this does often turn out to be The Case.
Such as emissions defeat devices.What with having a German farm trainee right now, the perennial joke atm, is that if some piece of kit is working well, it must perforce, have been engineered by Germans* -
The knob that controls the temperature on our oven broke. It's always been stiff to turn to the higher temperatures and it finally lost it's grip on the 'D' shaped spindle because it had cracked. I swapped the knob with the one that selects the oven's function as it was much easier to move. I thought of Aralditing the broken knob but wasn't sure it would be strong enough. I did a real Pikey repair using copper wire twisted around the broken section. Not pretty, but when on the oven you can't see it. Should outlast the oven.I haven't found exactly the right one yet, but similar ones found so far are what I would describe as EXTREMELY expensive - £9.50 - £15+ for just one plastic knob!
*** My rational way of dealing with such things is to leave the broken part where I can see it, as a reminder to do something about it, and to make sure that I know where it is. After 5 years, it was still there, next to the hob. 6 months of bubble pal visits later though, it has mysteriously disappeared. It may have been tidied away somewhere. Alternatively it might have been judged to be broken and useless, and therefore to be disposed of...!![]()
