Boon 51
- Deal. Kent.
Well I'm 61 so its almost a chat up line...
And I'm also 61 cycling for nearly 3 months now and the tights were a great buy - and following the commando advice on this thread by far the best way
Trust me it's not.It is my impression that riding commando would be the same as riding in the buff or your birthday suit.
Usually weight, you can get saddles that are more comfortable, but they usually weigh more, which is ok for general use, but if your trying to make the bike lighter not so, the choice of shorts/bibs is down to the riderMy wife has been feeling my tights (!). Commenting on the pad thingy she said why don't they just make the saddles more comfortable? Genius! But why don't they?
Trust me it's not.
Look at my name.Invariably when some tells me this I tend not to.
Trust me it's not.
Suppose that's why the W.N.B.Rides are only 6-8 to miles then.The reason that you wear padded shorts rather than use a "comfy" saddle is not down to weight, it is because the pad in the shorts moves with your anatomy, a saddle doesn't move with you, you move against it, hence you would be more likely to chafe over longer distances.
that and the british weatherSuppose that's why he W.N.B.Rides are only 6-8 to miles then.![]()
I've done the NBRSuppose that's why he W.N.B.Rides are only 6-8 to miles then.![]()
that and the british weatherbut not much
I suppose you could do both, I hope to do York this year.I've done the NBRin Southampton it's done a day earlier than the London one
Exactly! The reason many people find a Brooks comfortable is not that it is softer, it is because it fits, or has become fitted to your anatomy. The pad forms a friction barrier between your behind and the saddle. It moves with you. Underpants are not a good idea in that they can interfere with that barrier, and allow you to move against the pad, creating chafing. Some give in the saddle might be desirable to dampen vibration, but NOT softness.The reason that you wear padded shorts rather than use a "comfy" saddle is not down to weight, it is because the pad in the shorts moves with your anatomy, a saddle doesn't move with you, you move against it, hence you would be more likely to chafe over longer distances.
