Sittingduck
- Somewhere flat
Who took that pic? There is already a chainset attached, or is it a pic the seller took, before removing it and shipping?
that's got a standard (39/53) double on it.
I dont know sorry?I see the bike had electronic kit on it. Is the frame set up for standard cables?
im not sure however if the (39/53 double is any good?
I think you have made a mistake in buying this frame and you should try to return it.
The first pic shows the bike equipped with Shimano electronic shifter kit, you can see the front derailleur is clearly electronic shift. As others have pointed out this means you cannot fit non electronic kit primarily as you do not have any downtube bosses to route the cables thru. You will end up with a bodge solution unless you go Ui2 but you need megabucks to do that.
My recommendation is to go back with a grovel to the seller and attempt to return the frame, or save up the £££'s for a Ui group set plus another few hundred for the finishing kit, wheels etc.
Internal cable routing!
