To put the record straight.
There are three forces acting on a rolling vehicle which impede its motion.
1/ Rolling resistance of the tyres. - Energy to deform the rubber and absorb heat due friction with the roadsurface.
2/ Aerodynamic Drag. - The energy it takes to move the volume of air the vehicle intends to occupy and the reduction in pressure following the vehicle causing a rearward movement.
3/ Gravity. - The mass of the vehicle and the position of its 'centre of gravity' relative to its 'plan centre'. ie Angle of inclination.
All downhill velocities will be
assisted by 3/, therefore elliminated from any 'speed boasting'.
Smooth clothing and 'tuck' positioning are an assistance, but valid for 'speed boasting'.
2/ is non - linear. The faster the velocity, the greater the force, and therefore the greater power is required to increase velocity. It requires more power to increase from 28 to 30 mph than it does to increase from 8 to 10 mph.
1/ is linear. If 10 Newtons are required at 10 mph, 20 N will be required at 20 mph and 30 N required at 30 mph. ( Do not take these figures at reality. They are merely to serve as an example )
I don't deal in Newtons. There is an equation to directly calculate HorsePower from Coefficient of Rolling Resistance and Coefficient of Drag.
Pf = ( Crr x (W/375) x V ) + ( CdA x (V^2/391) * (V/375) )
This is the 'Holy grail'
