max tyre pressure in 20" wheels
Monkreadusuk
Good Evening,
I've recently purchased a trike with 20" front wheels, the tyres say they can take a max of 100psi however they came from the shop at around 40psi. Is there any reason I can't up the pressure to 100psi like i did with my old DF bike?
Many Thanks,
Pikey
Waiting for the turbo to kick in...
Wiltshire
Mmmm what trike did you get?
Tim Hall
Crawley
It's going to depend on the tyre specification. What pressure is printed on the side? (I can't find Kenda K West tyres on the Kenda website)
raleighnut
they may be too 'rough' a ride at higher pressure, I'd slowly up them from about 60-65psi and see how you get on
I certainly wouldn't leave them at 45, you'd be risking a pinch flat if you clipped the edge of a pothole with 1 front wheel (and they are hard to avoid with all 3 wheels on a trike)
classic33
Leg End Member
I've got the four, on the Brox, at 110psi. Any load on the back and I'll drop it to around the 80 mark, lower limit for the tyres.
mrandmrspoves
Middle aged bald git.
Narfuk
40 PSI may not be too low depending on the weight of the rider, surface ridden etc. I would head them up to 60 - 70 psi as a good compromise between reduced rolling resistance and ride harshness, then adjust up or down according to personal preference. No reason not to go to max PSI if you want to just because it is a trike - in fact, I doubt that most tyre manufacturers calculate the variation of an extra wheel reducing absolute load on each tyre.
tyred
Ireland
What width are the tyres? I'm assuming 406 size here and they are usually quite wide in which case 40 - 50 is plenty.
