User76 said:Oooh, beware though. The mag variation is not always right, so it may be a bit iffy for accurate navigation.
That's fantastic. New maps are on order.wafflycat said:OS have a good facility online, where you can order your own map, centred on a specific spot. Example - if your place is at the edge of one of the standard maps, you can order one online which is centred on your place. Ok, it costs more, (£15.99 for a Landranger) but it means you've got the map you want, if you see what I mean.
http://leisure.ordnancesurvey.co.uk/osselect?_s_icmp=yIin8163
Hope the above helps
That's a great link, WC, as a bit of nosing around also took me to the OS OpenData Viewer. I have both the local codes downloading as I type and a DVD with the whole of England on its way in the post. Without costing a penny.wafflycat said:OS have a good facility online, where you can order your own map, centred on a specific spot. Example - if your place is at the edge of one of the standard maps, you can order one online which is centred on your place. Ok, it costs more, (£15.99 for a Landranger) but it means you've got the map you want, if you see what I mean.
