Making pedel removal easier.
400bhp
spray with wd40.
Leave for 24hrs
spray with wd40. Then try to remove
If it doesn't work, spray again with wd 40 and leave another 24 hrs. Repeat the steps above until it works free.
If you're brave, add a lump hammer and/or a blow torch to the equation.
Bman
Herts.
[QUOTE 1514628"]
I just use baby wipes.
[/quote]
Employing someone else to do it for me sounds good though :smile:
youngoldbloke
I have a standard pedal spanner, but I also have one for allen bolt fittings too, still usually costs me a knuckle or two though :rolleyes:
I see - I don't know of a pedal specific allen key tool .... I use a torque wrench with a hex bit (non-torque wrench would work fine). As many have said if you use copper grease when you put them back on you won't have problems in future - but best loosen them, re-grease and re-tighten from time to timeanyway.
Yeah I do all the grease thing but I don't torque pedals, (no idea why as I have a torque wrench?). I guess I probably over tighten them, (I have very little mecahnical sympathy!). Anyhoo, here's the pedal spanners I have, in fact the allen one is a normal pedal spanner as well, but I already had the normal one when I got this one :thumbsup:
youngoldbloke
Thanks - that looks quite handy. My link
edit: I don't torque the pedals either - just use the wrench to hold the hex bit.
weevil
Cambridgehsire
If the WD40 soak trick doesn't work, up the ante with PlusGas. WD40 is a jack of all trades. PlusGas is a master of one: it's a penetrating oil. It may help if you can concoct some sort of well. If the ends of the pedal threads are sub-flush to the inside of the crank arms, then you have a ready-made well. Just lie the bike on its side with the offending pedal downwards.
If you're applying a LOT of force to a hex key, make sure it's a REALLY good fit. Avoid cheap tools. My Bondhus keys have never let me down.
+1 for copper grease. You don't need to use much, so a small tub will probably outlast you.
Zoiders
If it's a proper ball ache I pull the chain set and remove the rings, crank spanner in a big vice vice and then offer the crank up to it.
Makes it easier to work on.
