Making Gear Push (under bar) easier to operate on kids bike.
Cycleops
Accra, Ghana
So they work properly.
But not with grease apparently.
T4tomo
We'll it took longer than I thought! But we got there.
Still trying to decide if I am going to oil the new chain!
Don't oil the new chain, run it with it's out of factory lube until it needs a top up, then degrease property, and use Squirt or similar wax based lube.
faster
I install gear cables dry, unless it's one of the Shimano ones that come pre lubricated.
If ever there's any suspicion of cable issues, I never bother lubricating - just replace the inner (with any stainless inner) and the short section of casing near the derailleur (with Shimano sp41 preferably) - a few quid at most and only a few minutes of work.
The casings near the handlebars last ages and can just be flushed out with wd40 whilst the inner is being changed.
Like a few others it seems, I'm of the opinion that greasing cables makes the shifting not quite as good and less reliable.
the snail
Chippenham
Some cables have a plastic liner that might react with oil or grease, I don't think they're designed to be lubricated. I would suggest that the OP lubricates the derailleur pivots, and take the brake arms off and clean/grease the pivots too.
Tom B
Tom B
Lancashire
Brakes are this week's job! And that's the plan.
