ed!
- London, NW8
Hello!
My wife has inherited a vintage Peugeot road bike (a bit like this) - sloping top tube, drops on the handlebar, gear lever for the rear (located on the handlebar stem).
She's not done much bike riding before, but wants to get into it and absolutely loves the bike. I have encouraged her to try other bikes, but she has her heart set on this, so I'd like to make it work for her. There are a few obstacles getting in the way, which I'm hoping I can get some advice on:
- Front (caliper) Brakes "judder" when gently applied. Looking at it closely, there doesn't look like there's the possibility to apply "toeing in" practice to them. The pads are new, but from maybe 3+ years ago. I was thinking of just replacing the whole unit with something newer, but unsure whether modern caliper brakes will fit (one thing i noticed is that the rear brake cable feeds into the brake housing from the bottom, as opposed to the top), or if tweaking can be done.
- She's not used to drop handle bars, and is most comfortable with hand on the top (not hoods). This offers less stability, so I was thinking of chaging the bar for a flat one, possibly with "horns". The brake levers currently on there have dual reaching points: on the drops and on the flat part of the bar. Do you think it would be easy to transfer them to say a horn type bar?
I can post some pictures up if that would help give some advice.
Thanks in advance.
Ed
Thanks in advance.
Ed
