Tanis8472
Chain could do with cleaning
Thank youChain could do with cleaning![]()
Nah the chain is 'toast' but it may not have wrecked the cogs yet.I reckon a good clean and lubrication could do wonders![]()
Same goes for your missusI reckon a good clean and lubrication could do wonders![]()
Don't let anyone on here get at you, you commute daily no doubt in all weather and it is easy to neglect a bit of maintenance, we have all done it. Your chain has come to the end of its life and 1600 miles isn't a bad life!Well, I went to the shop about 10 times because of some noise I was getting. Then I managed to adjust myself a bit and it was running ok. So I've been quite lazy since.. My commute was only 3.5 miles so I wasn't that bothered.
Worth trying a chain first though, and for future reference @cyana13 if you change the chain before it gets too worn then you can generally get 3 times the life out of the cassette.In the most basic form, the wear on a chain and thr rear sprockets is linked in that they "fit" together in the worn state
As soon as you change the cogs or the chain you have an issue as the two no longer "fit"
You may get away with changing one element,or it may skip (especially on the smaller cogs) in which case you need to change the other element as well
The other thing you need to factor in is the cost of tools
You will need a chain breaker chain whip and a suitable lock nut remover
Price will range from £20 - £30 depending on quality
He means a cassette lockring removal tool - which you will only need if you're going to change the cassette.a suitable lock nut remover
Before the inevitable query, this is the Mickle methodBit of a mickle, it will be fine![]()
