rogerzilla
I have a degree in engineering and I find the rear hinge/pivot quite offensive too - but, compared to the Moulton hinge on which it is undoubtedly based, it lasts remarkably well. The Moulton hinges use Oilite or plastic bearing bushes whereas the Brompton uses small, but rather more complex, mixed-material glacier bushes which are designed to retain grease and have an enormous load capacity per square mm. The main practical issue with the Brompton design is that it is not easily serviced or replaced using standard tools.
Sorry, not entirely on-topic, but it fits the "poor design that usually holds up ok" theme.
