This is a do upper bike. There was little play when pulling pin 🧷 it was a 6.35 and it’s got slop was wondering if you could sleeve it but with the Ti frame it would be stronger ?
You are right it really is a rubbish idea they say if you keep the clamps tight it should not ware I don’t see that !
Welding up the item and re drilling and sleeving using the Ti pin arrangement ?
That sounds unfortunate!
I don't know the dims of the hinge on the Ti frame, although it looks ballpark similar to the steel item.
Ti is typically less strong (its low density and corresponding specific strength is what makes it special), so dims etc being equal there should, in theory be no issue modding the steel frame to reflect the geomtry of the Ti job... although this would be uncharted territory and again I'm not sure about the properties of the cast hinge material.
In theory you could weld it up and rebore it; but again I don't think this would be easy - getting down full inside the the holes, ensuring they're clean to prevent porousity, the potential for heat to bugger up the brazing, possibly create hard spots depending on the carbon content of the casting.. burn all the paint off and hence require re-finishing. Plus You're faced with starting from scratch getting the holes re-cut and in the right place; which I imagine in itself would be non-trivial.
You could maybe look at drilling oversize to say 7mm in the centre and outside sections, pressing / bonding in some turned brass sleeves then reaming in situ to take the Ti pin (assuming the length is also correct - no idea if this is the case). This of course would still reduce the wall of the hinge and rely on a thin wall on the sleeve.
Tbh it's probably all heavily over-engineered, however given the complexity of the shape it's difficult to get an idea of stresses involved. If only I still had access FEA software..
As they did the rear triangle with bearings and pins why not the main hinge ?
Blatantly cost, sadly. It's clear from the T-line that they're savvy enough to do the job properly- they've just chosen not to
