DCBassman
- The lumpy far South West
Here it is.
Not sure I like the bars that way now...oh well.
Agree with you on the bars.
Thank you.Agree with you on the bars.
That's going to be a lovely bike when you've finished it!
What worked:
Cabled up.
Gears work, but see Fails.
Brakes work, but see Fails.
Fails:
Forgot to bring the damn brake blocks from home...
Pedals don't fit. Right diameter, but thread pitch very obviously different on this crankset.
Need thin wall socket to remove crankset. So BB not serviced yet.
In top gear, 50-11, the extra downtube on the mixte is *just* touching the chain. Drop a gear or on the small ring, it's fine.
Oh well...
Yes, that would do it, for certain. I just don't have one...one large 1mm thick washer put on the axle solved it.
But but... how does that affect the QR?one large 1mm thick washer put on the axle solved it.
Want me to drop a couple in the post?Yes, that would do it, for certain. I just don't have one...
You just slacken off the nut on the other end of the QR from the lever a little till the tension is back to normal.But but... how does that affect the QR?
Oh, yes please! i'll PM the address.Want me to drop a couple in the post?
Got it!You just slacken off the nut on the other end of the QR from the lever a little till the tension is back to normal.
More difficult to put in words than do.
Be aware that you need to have a bit of the Axle poking into the dropout still to locate the wheel as I posted to @Reynard earlierOh, yes please! i'll PM the address.
Got it!
Yup, understood. Really only needs half a mil extra, so should be fine.Be aware that you need to have a bit of the Axle poking into the dropout still to locate the wheel as I posted to @Reynard earlier
