Piscator
- East Anglia
I have a B&M Lumotech Lyt LED N Plus front light (and tail light with stand light) teamed with an S-A X-FDD front dynohub. This is a new set-up.
It all produces light as it should, but the problem is that I can't turn it off with the front light ON/OFF switch (feature signified by letter N in title) i.e. whether on or off, the whole system stays lit.
The wire from light (two spade +- connections) to hub is two wire, one black, one white. I have tried endless permutations, but either the light runs all the time or not at all.
I may be missing something simple here, but I'm beginning to wonder whether the on/off switch on the lamp is faulty.
I should add that I'm hopeless with electrics. All suggestions welcome, as this is infuriating.
