Lubrication
young Ed
sooooo then , nothing but raw crude then if you don't want anything synthetic on your chain ......... I oil the chain up good and wet then use a cloth to clean all the excess off then a few drops . the mickle maybe method if you like. it clears the crud off the chain and i do like a quiet bike. the B&Q chainsaw oil is working well still
i have heard of people using natural mineral oils, not sure but i'm fairly sure the chainsaw oil i use is natural. just use what works
if WD40 works for you @Citius then i'm not going to stop you but i know i wouldn't use it personally
Cheers Ed
subaqua
What’s the point
Leytonstone
Cheers Ed
the only natural mineral oil is crude. once its been through the refinery it has had all sorts of stuff added to it. which is not natural. and raw crude isn't that good a lubricant.
Citius
Cheers Ed
You need to go back and read what I said. I never said it 'works for me' or anything like that - I never even claimed to use it. I simply corrected your inaccurate assertion that it was not a lubricant.
Kumquat
A good squirt with WD40 is a good thing if the chain is covered in crap, then wipe (Mickle) it all off and lube properly (with chainsaw chain oil for me :becool:)
I considered getting chainsaw oil, but I could only find it in huge quantities that I really don't need! Got some unbranded bike stuff with teflon in from decathlon, cheaper than I could find elsewhere.
Gravity Aided
Land of Lincoln
Because some people don't believe in chainsaw oil.
Truth
Truth
Boardman Hybrid Team 2016 , Boardman Hybrid Comp
Coseley
What I do is spray the GT85 onto an old t shirt and run the chain through it to just clean the outside of the chain as much as anything
Then spin the chain again while dripping a bit of Teflon all weather lube into the centre of the chain.
Do this once a week, I commute 3 times a week usually, a total of about 70 miles each week.
Sorted :smile:
