MartinC
- Cheltenham
In Ireland an alcoholic is someone who drinks more than their doctor.
Rip Van said:Well, what is the point of alcohol free beer and wine?![]()
In any alcoholic drink, the ingredient with the most calories per gram is alcohol. The second is the residual sugar. So if your target is to get plastered for the least calories, go for the driest-tasting version of the strongest drink e.g. vodka. The calculation is made slightly more complicated by the fact that some drinks have higher osmotic pressure than others and with very weak drinks the volume will make the alcohol slow to absorb; and most people find that fizzy drinks get them drunk quicker. You should also note that the stomach has a valve which closes as soon as food enters, which again keeps alcohol out of the gut where it is absorbed much more quickly than in the stomach.earth said:I could go for spirits and diet mixers but I like to drink a reasonable quantity to get plastered....I also tend to avoid artificial sweeteners.
Anyone got any suggestions?
ASC1951 said:In any alcoholic drink, the ingredient with the most calories per gram is alcohol. The second is the residual sugar. So if your target is to get plastered for the least calories, go for the driest-tasting version of the strongest drink e.g. vodka. The calculation is made slightly more complicated by the fact that some drinks have higher osmotic pressure than others and with very weak drinks the volume will make the alcohol slow to absorb; and most people find that fizzy drinks get them drunk quicker. You should also note that the stomach has a valve which closes as soon as food enters, which again keeps alcohol out of the gut where it is absorbed much more quickly than in the stomach.
So your drink of choice should be a bottle of 13% champagne or 2 litres of high-strength dry cider, necked as soon as you get both feet out of the pedals. White Lightning was produced just below the excise band at 7.5% and generally reckoned to be the best 'bang per buck' for student parties and the back streets of industrial Britain. Heineken withdrew it last year because of its park bench image, but there are replacements, as you have already discovered.
Or - as Globalti has suggested - you could just grow up.![]()
Cheap lager? Although not too cheap unless you want to give up drinking then try Sainsbury's basics lager, it's so horrible you wont want to drink much of itearth said:Anyone got any suggestions?
