spire
To the point
Now this may sound pedantic, but bear with me.
Your tyre is recommended to be inflated to 120psi, so you do this.
When you disconnect from the valve there is a brief rush of air.
If you were really keen, should you then immediately check the pressure again to see how much it had dropped in order that you could over-inflate by the same amount next time?
