Losing tyre pressure...
Leodis
Moortown, Leeds
I am not sure if this is normal as I cant remember having the problem before BUT... I am running on some very cheap Wiggle tubes and I am losing about 10-15 PSI over 3 days 30-40 odd miles, is this right or should I replace them with some decent ones?
Ta
Roadrider48
Voice of the people
Londonistan
Maybe a slightly faulty valve.
Kies
probably a slightly faulty valve, i have that on my road bike as well. havn't got round to swapping the tube out yet
Leodis
Leodis
Moortown, Leeds
Thanks, its both of them so I was thinking they are crap tubes. Will replace in due course as I was thinking of ordering some more, anyone else used them Lifeline tubes from Wiggle? Got them on the Ribble and they see ok, though it hasnt been used for a month but seem to be holding air.
Chris1983
My conti tubes lose around 10 to 15PSI a month, if that...
Presta Valves are a pain, a couple of things to check,
Make sure the center pin isn't bent, they can bend easy when removing a pump...if its bent replace the tubes as it might not be seating correctly at the valve seal.
make sure the valve is screwed in tight...not the locking nut the centre of the valve...if this is finger tight try tightening ever so slightly more with a pair of pliers...but i mean i slight nip, nothing more or you risk damaging the valve.
final thing to check is that the locking nut is tight....finger tight it fine...don't use pliers on this one...
Wiggle/CRC normally do a bulk buy of 5 conti tubes for a good price...last time i got some i split the costs with a friend, he had 2 tubes and i had 3...worked out at about £3 a tube :smile:
Cheers
Chris
Leodis
Leodis
Moortown, Leeds
Thanks guys, will pick some better ones up this weekend and faze these ones out.
Schwalbe or conti's?
Smurfy
Naturist Smurf
My commuter has presta valves that have to be screwed up really tight or they lose air. They're the ones that came with the bike and I've never bothered replacing them with something better.
Leodis
Leodis
Moortown, Leeds
Thanks for all the advice, I double checked last night and the rear was not tight, will keep an eye on them over the next couple of weeks but will phase in decent ones.
