gaz
Cycle Camera TV
- South Croydon
So whilst we aren't owning these high streets, what will 'you' be doing to get those 86% of people on a bike?
You may call something from a doubling to a quintupling (depending on how percentages have been rounded) negligible. I do not.Yes, and when you look at Table 2.4 on p.43, we see that this claim is based on a rise from 1% in 1993, to 2% in 2008. This is far from stratospheric. In fact - given that we are dealing with "small percentages"*, it is negligible.
A fascinating link. And one which is rather more complex than the "bike lane = good" message you seem to be promoting.Meanwhile here are some modal share figures from across western Europe -
Cycling levels will continue to stagnate while the road environment stays as it is.
I suspect - deep down - you are fully aware of this, and your unnecessary diatribes about Holland are a rather desperate attempt to deal with the cognitive dissonance.
Section 1.2 distinguishes between those cities which have in the past had an explicitly pro-car development policy and have seen bike use drop and those that have not. So pro-car policy is bad for bikes. Score one for central London - it's got an anti-car policy now.
Figure 8 explicitly, and clearly, supports the "safety in numbers" argument.
PDF page 15 - Groningen - an anti-car policy has resulted in lots of bikes.
PDF page 16 - Amsterdam - creation and maintenance of a bike network is only part of a raft of measure, headed by increasing bike parking.
Chapter 4 - the measures that the Netherlands thinks are important in encouraging cycling:
1. Town planning
2. Traffic infrastucture (not just bike infrastructure) which improves traffic safety (not bike safety), is direct, comfortable, attractive and cohesive for cycling - and which discourages private car use
3. Bike parking
4. Tackling theft
5. Education
The section on infrastructure is particularly interesting - it highlights that cyclists will tend to prefer quiet mixed roads to dedicated lanes on or near arterial roads, for instance.
And that completely separated cycle networks become unpopular because they're perceived not to be safe.
Granted. But you do realise that the percentages could also have been rounded from 1.4 to 1, and from 1.6 to 2? That would not look quite so impressive.
Cycling in London has soared in the past five years by more than 80%. Overall modal share across Greater London remains low at less than 2% of all journeys (including car, tube, rail, taxi, bus and walking) but it is much higher in some parts of London. In the morning peak in Central London the ratio of bikes to private cars is now 1 to 3. In Hackney cycling’s modal share is estimated at more than 10% of journeys. Cycling‘s highest modal share in the UK is in Cambridge with 28% followed by York 19% and Oxford 17%.
Here's the LCC in 2008:
http://www.lcc.org.u...asp?PageID=1142
Figure 13.3 (PDF page 335/379) of the TFL doc is instructive, too. It shows that between 2000 ad 2003 cyclist numbers were, on average, static, with gradually increasing summer peaks. They then took off in 2003, with continuous increases since. There is no obvious "bomb-dodger" effect in 2005. The summer 2010 peak was more than two and a half times the summer 2000 peak.
It is instructive to note that these counts are taken on the road network that TFL is responsible for - that is, the main arterial roads in central and inner London. So even though people say that they are put off by traffic, that is increasingly not the case in practice.
Personally I'd love a network of well-maintained paths with very limited traffic. But it ain't going to happen in London - except in central London, where the congestion charge has effectively created it.
(still waiting for that drawing........)
You've been waiting since you last asked me because I have not been online today.![]()
Anyway, you post the map, I'll scribble on it. I don't have many 1:1250 maps of London to hand.
It's very difficult to measure, and very few people bother.What I find interesting is that Hackney's modal share - so proudly trumpeted here by the LCC - is, in the latest TfL document, back down to 4%. This runs rather counter to the breezy optimism displayed in that article. Explanation?
I don't doubt that we are seeing an increase in arterial cycling in at commuting periods. I would suggest that this largely due to a number of commuters pragmatically switching modes, after getting fed up with congestion in outer London, which has increased over the same period.
But these are very small gains,
the results of the survey conducted by TfL show that only 1% of the users of the Cycle Superhighways had started to use their bikes because of it
I don't want you to scribble. I want you to draw it. A 3M wide cycle path at 1:1250 is 2.4mm wide. You go to the library, you get the maps, you draw the parallel lines 2.4mm apart. It's not difficult to draw the lines, but it is impossible to draw the lines without coming up with a scheme that causes a whole lot of inconvenience and stupidity (see list above and add wheelchair accessible kerbs with the proper gradients).You've been waiting since you last asked me because I have not been online today.![]()
