So just fitted my new Joseph Kuosac bars from SJS Cycles and im pleased with the look and the feel of them. A very quick ride gave me the impression of improved control and stability. Also a very slight change in posture too. I have not cut them down, standard length is 600mm from the stock bars which are 522mm but I will see how I go on. Not had to change the cables which is sort of an added bonus. However you cannot fold the handlebar stem because the cables are not long enough. So there are positives & negatives but I only tend to fold the back end anyway. I may look into either cutting the bars down but if it means cutting them down to a similar length to the stock bars then I will go with lengthened cables.
If you have done this mod then im interested to know your findings and how you went on.
