The Jogger
- Spain
I have a T6 torch (deal extreme) you csn be going along and all of a sudden it goes dim for no reason. Anybody know why this happens?
If it's very bumpy and especially If the battery is getting low the current can be interrupted sufficiently for the light to cycle through its modes, as if you'd depressed the clicky switch or turned it off and on. This can be reduced by increasing the grip of the springs on the battery. You can do this several ways, increase the length of the battery with some tin foil ( make sure it's insulated from the sides of the torch, or reducing the travel of the spring by inserting squares of foil on the coils etc.I have a T6 torch (deal extreme) you csn be going along and all of a sudden it goes dim for no reason. Anybody know why this happens?
As long as your charger voltage matches the battery pack voltage you will be fine, don't try and charge a 4.2v battery pack with an 8v charger!Another question and thanks Svendo for answering the last one, I just dug out a cree T6 which I bought last xmas and it's been in the shed since so it needs re-charging.So to re-charge these do I plug the battery lead which goes into the light into the plug charger? For my T6 torch I use the charges I got from torchy and charge two batteries at a time. This is what I've done ATM.
Ordered two of these so one will be spare if anybody wants one?
First dibs pleaseOrdered two of these so one will be spare if anybody wants one?
Sure, will let you know when they arrive, Merry XmasFirst dibs please
Thanks for the heads up- ordered. A couple of questions if anyone can help....can I use the charger that came with my Solarstorm light, or do I need to buy one like a Nitecore i4? Also I want as long as possible between charges, but I only use for about 30 mins a day. Are these the best batteries I could get? (although sold out at moment!) http://www.ebay.co.uk/itm/2x-Torchy...rElectronics_Batteries_SM&hash=item462edab896 Do I need flat top or raised?
Yes you can use your Solar storm charger, the connector will be compatible. A Nitecore charger would be a future upgrade if you want to keep your batteries in balance.Thanks for the heads up- ordered. A couple of questions if anyone can help....can I use the charger that came with my Solarstorm light, or do I need to buy one like a Nitecore i4? Also I want as long as possible between charges, but I only use for about 30 mins a day. Are these the best batteries I could get? (although sold out at moment!) http://www.ebay.co.uk/itm/2x-Torchy...rElectronics_Batteries_SM&hash=item462edab896 Do I need flat top or raised?
Yes it will take any typeCheers Tincaman- and flat top are ok?
