JoeyB
Go on, tilt your head!
- Fareham, Hampshire
I just bought a second battery pack for my Cree T6 jobby, doesnt get used much but need the life on the night ride next week
You can build a 4 cell pack using two two packs wired in parallel. I'm not sure how handy you are with a solder or about the availability of packs or cases though.
There are advantages to charging cells induvidually or in performance matched pairs if I recall correctly, is it something to with that?I have most thing I need to do this including a protection PCB but I much prefer the type of pack with removable batteries
Yes something like that, every battery pack I have had has had to be disassembled to remove a duff or unbalanced cell, so the idea is to have a pack which can be charged as normal but have the ability to take apart easily and repair. Also you get to choose the quality of the cells you are using.There are advantages to charging cells induvidually or in performance matched pairs if I recall correctly, is it something to with that?
Something like this, i think this is the pack that fossy bought recently http://www.aliexpress.com/item/Sola...tery-case-used-for-bike-light/1314568186.htmlYes something like that, every battery pack I have had has had to be disassembled to remove a duff or unbalanced cell, so the idea is to have a pack which can be charged as normal but have the ability to take apart easily and repair. Also you get to choose the quality of the cells you are using.
I have one of those, but the new light unit runs on 4.2v, these packs take 2 or 4 cells to make 8.4v. I was thinking about the risk of trying to run the new light on 8,4vSomething like this, i think this is the pack that fossy bought recently http://www.aliexpress.com/item/Sola...tery-case-used-for-bike-light/1314568186.html
You might get a few seconds before it blows. Don't they do a 2 cell version?I have one of those, but the new light unit runs on 4.2v, these packs take 2 or 4 cells to make 8.4v. I was thinking about the risk of trying to run the new light on 8,4v
Most 4 cell packs are 8.4v 2S2P (2 series 2 parallel) I could make a 4P to get me 4.2v, but I would like a suitable battery holder instead of soldering the pack together. Alternatively source another of the 2 cell 4.2v packs and wire them in parallel with a splitter cableYou might get a few seconds before it blows. Don't they do a 2 cell version?
"Compatibility: 2 or 4 pieces 18650 li-ion batteries in any capacity."
There's a fix. The specs say it'll run with 2 batteries. As it's 2 in parallel and 2 in series, it should (don't quote me) take 2 in the right way to give you the 4.2v you want.
