- South Manchester
Ahem- any of them packs left over Foss?
Just one left ! For you no probs. PM me if you want to collect or post ! Post is £12.60 due to £2.60 postal costs - bah !
One could be a smaller pin. Most lights are the magicshine 'size' but a few are a little smaller. One pin is 2.1mm the other 2.3mm, but I can't remember which. You can get adapters from Maplin. It could indeed be wired differently.
searched back upon some old posts of mine from TWO years ago !
These cheaper models have a slightly larger connector (2.5mm vs 2.1mm on the MS) but you can get adapters from Maplin.
@Supersuperleeds I think this is the correct one ! Have a look at the pins on both batteries, and the male connectors to see if this is the case.
The light arrived yesterday morning so I put it on charge for the afternoon and went out with it yesterday evening.
I only did 26km and it was on one of the lower settings for most of the time. Even so, the switch started flashing red when I was some way from home. Luckily, I still had the freshly charged battery from my other Magic-Shine-a-like on the bars (as well as my E3 dyno light) so I got back OK.
The remote switch works well but not in the way I'd wanted it to; it cycles through all the settings in turn and then switches off (centre light; both side lights; all 3; off) so it doesn't do "dip", "high" like I'd wanted it to.
Another wasted opportunity is the nature of the beams; they're all conical spots. It would be better if the outer lights had a spread beam. I couldn't detect much difference between any of them and I mostly ran with just the centre light switched on to eke out the battery a little longer.
It is impressively bright; I was on the Fallowfield Loop last night and it was really dark but this thing really lit everything up.
Everything considered, I think I'm going to send it back. If it had been £20, I'd keep it.
It looks like I'll have to start saving for an Exposure Strada.
Dear Santa..................
Adapters didn't work, but I don't really care, had nearly 5 hours out of the new battery pack on full beam and it is still on green, even that's enough to last me a couple of days![]()
Wow, that's the difference between cheap packs ! Blimey. Not tested my packs as I run 2 of those c&bSeen rear lights off one pack, and they do eat the batteries. Can't compare to front lights though.
Your other light must be wired differently. Oh that reminds me, FED Ex have charged me £14 for handling for the packs - better pay it !
Got another 90 minutes this morning before the red light came on, so I estimate pretty close to 6 1/2 hours of full beam. If you didn't factor the £14 into the costs I am happy to contribute
Just awaiting a couple of 'commuter' lights (apparently they use the new L2 LED) which have an outer glow ring (aka angel eyes) for side visibility. Apparently the "glow rings" are bright enough on their own.
Have you just bought more lights?
Think the Tramadol is having side effects.![]()
Don't know what you are talking about![]()
