Lights - Blackburn Flea 2 USB Front Light
Egon Belmontie
Powered by Marmite.
Hi all,
Just wanted to spread the word about how great these little USB lights are,
The front and rear did cost me £50 (because in Gibraltar there's no VAT so the shops just jack up the price) but online you can get them for about £25 and there just great!
3 settting, high beam, bright and flash,
They will last for about 2.5 hours on high beam before a red warning light shows up on top then you get about another hour before you notice that they are starting to dim,
I use them on flash day and night all week long on my commute,
And they take less than an hour to fully charge via a usb.
Im guessing for the more hardcore/longer commutes there maybe a little over priced and under powered, but for me they are perfect all rounders.
http://www.chainreactioncycles.com/Models.aspx?ModelID=57982
  • Ultra compact rechargeable Li-Ion headlight
  • Uses four super-bright White Nichia™ LED’s
  • 40 lumen output
  • Includes USB charger
  • Flexible and compact mounting system
  • Standard, Overdrive and Flash modes
  • Superlight at 17 grams
  • 3 hour runtime steady, 5 hour runtime flash
  • Compatible with Solar 1.5V chargers (available separately)
  • LED's: 4 Ultrabright Nichia White
  • Run Time (Steady/Flash): 3-5hrs
  • Batteries: Internal Lithium Ion Rechargeable
  • Charging: USB charger included
