DEFENDER01
- Essex
Looks like this could be useful to carry just in case.
Hmm don't think there is much difference weight wise they are very small.Or just carry a much smaller, lighter inner tube?
These weigh ~91g so much lighter than an MTB inner and a little more than a 'normal' road inner. But larger volume-wise so more difficult to pack.don't think there is much difference weight wise they are very small.
Yes. Fire and forget/hope.is it a one shot can?
If you look at the image you may see the schrader to presta adapter at the end of the tube. This is worth carrying anyway in case one needs to use a garage or other schrader only pump.Do they fit presta valves or just Schrader?
Obviously not using it right.I guy turned up for one of our mid-week club runs with only one of those seal/inflate cans, it was worse than useless when he got a puncture and he ended up getting a train home.
They look like they fit Schrader and ordinary valves onlyDo they fit presta valves or just Schrader?
What's an 'ordinary' valve? A 'Woods'? [The adapter provided would fit that too, btw.]They look like they fit Schrader and ordinary valves only
They're at best a temporary get you home fix. And they usually render the tyre unrepairable on cars. Your daughters car needs a new tyre. Like, immediately. It's utterly unsafe and I don't want to share the road with it.Obviously not using it right.
Used one on my daughters car just under a year ago still o/k.
