Lezyene Pre Glued Patches
ianrauk
Tattooed Beat Messiah
Rides Ti2
[QUOTE="w00hoo_kent, post: 3608688, member: 36674"
I failed to use them properly to start off with, but once I got the hang of the whole 'hold 'em tight for 30 seconds to stick them all down' bit I've not had a failure.[/QUOTE]
^^ This is the key to successful use of pre-glues patches.
ANT 666
Trying to re member
N.Wales
I had some park patches for about a year before i needed to use them then they were no good, would not stick. as i bought them as a last resort (I always carry at least 2 tubes) I was not impressed. Can't see the point of having them if after a certain amount of time they give up, just a waste of cash.
Arjimlad
Tights of Cydonia
South Glos
As long as you roughen the tube I have found Lezyne patches 100% reliable. Holding 120psi for ages..
Not just a "get you home" repair... a permanent repair.
I was once misled into buying some Evans own brand patches which er, weren't a patch on the Lezyne ones.
so what did I do wrong? Patch held for 3 days and about 500km (audax) at 120psi. I'm pretty sure I roughened it, and stuck it under a table leg for a few minutes to make it hold. Bubble was raised under the patch when I examined it, and it peeled off cleanly with some effort. Hole was a 2 or 3mm slit in tube. Patch failed while bike was hanging from a hook, 9 hours after last ride.
Repatch or bin?
Fastpedaller
Norfolk
Ancient thread resurrection time :laugh:
We were placing a Temu order so I included 'glueless patches' for IIRC 54p for 10
My thought being that I carry a tube or 2, if getting a puncture it's not easy to use glue (unless it's never been opened, it may be dried) so if a glueless patch gets me home, that's good enough. Earlier comments suggest they may be useful for such an emergency.
It's cold in the garage so I may try a test on an old tube and report back.
Fastpedaller
Norfolk
I tried one a short while ago. The temperature in the garage was 7 degrees. I considered using some 320 grit paper to roughen the tube, but settled for the (quite sharp and viscious-looking) metal 'tool' provided - it worked surprisingly well. The patch was applied and held firm with finger/thumb pressure for several seconds. As the test was on an old (cut through) piece of tube, I was unable to test it with air pressure, however, it needed a sharp fingernail and considerable tension to remove it. I concluded it was very likely to work as a get-me-home repair.
54p well spent :laugh: :bicycle:
froze
People who preach new tubes every time they get a flat are people who don't know how to repair a tube.
I haven't tried the Lezyne glueless patches, but for a long time I used Park glueless and they held on permanently, but something changed and now they don't hold for more than a day, so I went back to Rema glue on patches. But I think I will buy those Lezyne glueless patches and see how they work.
