cyberknight
- Land of confusion
I replaced my sqaure taper BB and ever since that the bolts keep working loose no matter how tight and i get a creak at the start of every pedal stroke on the left hand side, i have tried single side pedaling and its definitely just coming from the left side and it gets worse untill i tighten up the bolt .
When i do tighten the bolt it makes the same sort of creak .
I have read on another thread that it could be done to a bit of play between slightly worn crank and new bottom bracket ?
The cranks i use are 170 mm square taper , so i have been looking at these, would it be best to go for both side ?
( i use a standard 50/34 compact 5 point chainring. 110 bcd i think ...) on a carrera virtuoso
http://www.ebay.co.u...=item3a6a6e7efc
http://www.ebay.co.u...=item2a140b63c4
http://www.sjscycles...41/?src=froogle
And would it be best to get some new bolts?
