Lateral flow tests - kits - anyone managed to get any?
Blue Hills
London
Is there a positive sign of a successful/valid sample though. I find the tonsils thing tricky - the instructions are awash with warnings about not touching anything else (tongue, inner cheek etc) which can be tricky.
Or can you skip the tonsils tickling and just do the nose bit - seem to remember some instruction which said you could.
Julia9054
Knaresborough
It depends on the brand of test you've got. Fortunately I have no supply issues as I get them from school but we have recently swapped over from the nose and throat to the just nose type.
T4tomo
Yes latest boxes we've got are nose only, thankfully. I gag something rotten doing the throat bit and the OH takes the mick mercilessly
Blue Hills
London
am i unusually stupid in not really knowing where EXACTLY my tonsils are? The kit i had gave no info, while stressing stressing that you shouldn't touch anything else.
T4tomo
think of them as throat bollocks
Landsurfer
Don't assume this will protect you. My son and his partner have both had Covid and double jabbed. She tested LFT positive yesterday and both are taking PCRs today.
They won't be driving home for Christmas.
Ok, but are they ill ..... My friend is the the senior nurse at a South Yorks hospital .... she and 3 of her nurses are at home after testing positive .... non are even slightly ill .... at home for 10 days watching netflix while Rome burns ... she’s been at home 5 days and tested negative with a LFT but will not be allowed back to work ...
winjim
The tests don't control for correct sampling. Our nucleic acid amplification analysers at work don't either. They control for test validity and presence of interferents. As I understand it, it is possible to control for sampling to an extent with PCR assay but they don't do it routinely.
classic33
Leg End Member
I thought part of the idea behind all this testing was to identity who may be carrying the virus, and limit the spread.
It is possible to carry a disease and not be affected by it. One of the best known cases being "Typhoid Mary". Known to have killed at least 51, and who spent the last 23 years of her life in quarantine. She tested negative as well, every time she was tested for it.
PaulSB
They're at the back of the throat if you still have them. Basically get the swab as far back as you can. At the point of being about to gag you're there. I don't want to put you off but I found it deeply unpleasant.
Our last three boxes have been nose only which is a great improvement. I wonder if it leads to better results? If people don't like gagging they may not test the correct area?
PaulSB
Precisely but there are always people who find reason why they should not cooperate for the greater good of society.
I've known examples of people criticising the Zoe study for being intrusive in it's need for personal details only to praise the results.
They were giving them and masks out in Kingston on Sunday. I also got a box from pharmacy last week with code (I'm having to LFT daily as a close contact, do much prefer nose only ones)
Low Gear Guy
Surrey
There are no lateral flow tests available on line or the two nearest pharmacists. I don't have the time or inclination to tour the country for some in stock as I am working full time.
We are currently waiting for a PCR test result and the rest of the household should be doing a daily test but we will have run out by the end of the week.
Ah well, that should keep the reported positive test results down. Perhaps it will all be over by Christmas.
Blue Hills
London
Thanks Paul, i seem to recall that the instructions on mine said throat THEN nose (though maybe you could just do the nose)
