Hi Nigel..........this setup; Spa cycles touring chainset (seems very good for the money) and a slightly larger cogged cassette (28 teeth?) is exactly what I had in mind for my Triban 3 one day soon...........figuring it might make Dartmoors hills more doable for me. I presume I would need the 110 mm bb but wonder whether a new (mtb style) rear mech would be absolutely necessary. Does this combo really make the difference in your opinion? Part of me is just tempted to stick with what I have (50-39-30 and 12-25) and man-up to the occasional grind............but my God it's still hard around my neck of the woods..........plus....next year I would like to get into a bit of 'light' touring, (few days maybe with tiny-tent and panniers) and reckon the spacycles options would be really good for the job. what would you recommend?
Best
w
If you are going touring, then you need low gearing its not really about speed, the thing about changing the chain set you will need to lower the front mech down the tube (no big deal really), when I first started messing about with the gears I got a 12/14/16/18/21/24/34 cassette of
ebay (I caught a bungee hook in it and it bent), the 34 on the 30T front made a huge difference to me, that equated to 23.8" gain as opposed to my current low (26T-28T) of 25.1" so it is actually lower, but there was a massive jump from 2nd to 1st (29%, thats like 2-3 gears, my current is 14%). Most road Dérailleurs wont cope with such a large range, so I got an Acera M.T.B. Dérailleur since you have an 8sp I believe one option would be to replace the rear cassette with an 11/13/15/18/21/24/28/32 (there three Shimano cassettes that I know of that cover this range HG31/41/51 teeth cominations vary slighty) the 30/32 combination would give you 25.3" gain almost the same as my 26/28 @ 25.1"
I suspect the 12-25 is an HG50 12/13/15/17/19/21/23/25, so you would gain extra at the top and bottom, but you will lose the smooth stepping between gears, thought to be fair I didn't notice, though some combinations I tried just didn't work for me at the time (I make up my own ratios from stripped cassettes).
So your HG51 Cassette is currently £15
http://www.wiggle.co.uk/shimano-cs-..._campaign=uk&gclid=CIiS59KV47MCFczHtAodejQAaw
A rear mech from £18
http://www.wiggle.co.uk/shimano/cycle/mtb/rear-derailleurs/?o=2
and a new chain.
It will give you 122.7" to 25.3" gain range, sacrificing the smoother transition of a road cassette.
Hope this helps
