U
User482
Fnaar said:Q: What does a Mexican carpet fitter say?
A: Underlay! underlay!
Mr Fnaar, your coat sir.
col said:I seem to remember that the dust from the cheaper boards is dangerous if inhaled,a mask is a must,if your cutting them,obviously it doesnt apply so much to real wood ones.
yorkshiregoth said:Mrs Goth wants me to get laminate flooring put down in the spare room. As I am completely naff at anything DIY, I plan on buying the laminate flooring myself and then getting someone to lay it.
meenaghman said:You can get the kit from B&Q and other DIY places to keep the boards wedged in tight. Also its NB not to start at the edge of the wall especially if an old house as its bound to be crooked.. mark a straight line a couple of inches out from the wall and use pieces of wood to keep your first laydown straight. Are you doing a major redecoration eg painting ? in which case may be advisable to remove skirting and skirt over the floor. The other option is some edging. Use an appropriate underlay material even downstairs as this helps floor float especially if the underlying floor is rough and uneven and also provides some thermal and sound insulation.
Top Tip from my teacher : To cut straight with a handsaw dont look at the saw.. look at where you're cutting to.. same as driving/cycling.. look ahead.
Finally lay the surround sound speaker cables before you lay the floor !
