Ladies' Favorit 1981
Chris S
Birmingham
It's hard to see from the photo but are those brake levers for linear pull brakes? They may not give enough leverage with calliper brakes.
dimrub
dimrub
I must confess I don't know the answer to this. I went back to the Aliexpress listing, and it is not clear on this point either. I guess I'll need to try and adjust the brakes and see whether they can generate enough pull to actually break - unless there's a way to tell based on their look?
Chris S
Birmingham
Linear pull brake levers have to move more cable with less force. They're shorter than caliper brake levers and have an obvious angle in them.
Caliper brake levers are longer as they need to apply more force. Ideally they should be straight but they usually have a slight curve in them for ergonomic reasons.
dimrub
dimrub
Went back and adjusted the brakes today. Seems like the levers were the correct type. At least the front brake worked perfectly almost immediately. The rear one is giving me a bit of grief. The cable keeps sagging, and I'd be happier if the caliper arms were a couple of milimeters longer - the pads are not fully aligned against the rims. The wheels are also not as aligned as I thought - but luckily, my proper new truing stand is here, and here's a perfect chance to use it. But never mind that, the gears are connected and sort of aligned, and I can do a test ride tomorrow, then deal with the finer adjustments.
dimrub
dimrub
Did a test ride today. Very nice riding for a city bike. Some more tweaking is required:
- Having another go at retruing the wheels
- Perhaps a better adjustment of the gears
- Connecting the lights
But other than that, it's done. The brakes work great, much better than expected.
dimrub
dimrub
I'm starting to sell off my collection: they were kept in a basement, which doubles up as a bomb shelter, and recently a different use case arose for this space. This one is up first. I'll actually be happy to pass it on and to know someone is actually riding it.
Paulus
Barnet,
I've just caught up with your restoration of this bike.
Well done.
dimrub
dimrub
This is now gone - sold to lovely Meirav in Tel-Aviv, who was quite excited about the bike - the looks of it, and the difference between the restored and original versions of it.
