dimrub
Not to be confused with a ladies' favorite.
Favorit is a Czech company, founded in 1901 in the city of Rokycany, here's more about its distinguished history. The company still exists today, and still produces bicycles.
This is the bicycle:
So this is a lugged steel frame with single-speed coaster brake rear hub, cottered crank arms and what appears to be hints of original crimson-red paint job. But there's more. Well, a bit more:
Yes, a preparation for cable routing, either gears or brakes, possibly both. Why is it there? Was this bike a multi-gear at some point in its past and then converted to single-speed - or do they put these braze-ons on all of their frames, to streamline the production process? I suspect the latter.
It would be relatively easy to just bring this bike back to life: strip it, clean it, repaint it, replace the tires, the seat, some of the spokes (I hope both of the rims are salvageable, although there are some doubts about the rear one), put on lights, cut down or replace the ridiculous handlebar bolt - and hey presto, a single-speed coaster brake ladies' bike is reborn. Nah, I don't want that. I see it as a 3-speed internal gears bike with proper (central pivot, obviously) brakes.
So what would that entail? First of all, naturally, figuring out the dropout distance:
It's 109mm, but let's call it 110, shall we? So now I need to either source a 110 OLD hub, or cold-set the frame to 120mm which, according to S.B., is the common distance for internal gear hubs. So the algorithm seems to be:
1. Figure out whether 110 OLD hubs exist in this timeline, and whether one can buy one without involving one's bank's mortgage department.
2. If successfull - goody. Source the aforementioned hub and proceed with cleaning the bike.
3. If not - cold-set the frame to 120mm
4. If successfull - source a 120mm hub
5. If not - abandon the project, since lack of success probably means that I've ruined the frame.
