russ.will
Slimboy Fat
- The Fen Edge
.... and I should have mentioned - Your thread on the 3100 was very useful. I'll keep it on the list.
.... and I should have mentioned - Your thread on the 3100 was very useful. I'll keep it on the list.![]()
Yes. There's a few things I'm going to have to buy as a result of this arrival and that's on the list!I'm no roadie, but that looks like a helluva bike to me.
As you like things just so, might be worth putting some carbon paste on the seatpost, which looks dry in the pics.
It was things like that made me take the plunge. The frame is Di2 specific, with no rubber plugs covering up unused gear cable holes and stuff like that - All the details seem thought out.Lovely looking bike. I like the little touch of the holder for the Di2 control box, which is a lot neater than the band around the stem.
To be fair, it arrived like that, so you can blame the journos. They clearly didn't work out that once you undo the seat clamp bolt, you have to give it a good hard shove to loosen the other side, at which point the post slides up and down quite freely. But no, they just graunched it up and down...
Russell
Pure luck.Gorgeous bike.
How did you strike on an ex-demo one?
Now that is a Top Tip Viz would be proud of, but there's a Di2 battery in that location and CF paste might be conductive?I can't resist sharing my slightly anal carbon paste tip.
When you apply some to the seat post, put a little on the inside of the open end of the post.
It doesn't do anything, but will be there to be used when you remove the post in the future and need to apply another smear.
<EDIT> Just went and had a look and it's the alloy Ritchey WCS seat post.
Russell
As your aesthetic discrimination is clearly highly refined, I'll take a better picture once I have the right length stem on, the right way up and with the bars set level, rather than compensating for a reach that is about 20mm too far. At that point, I'll be nursing a semi.Now that is friggin gorgeous.... me want's.... me want's lots and lot's.
