KMC Missing link
They can be a faff sometimes IME, try squeezing the plates together, (inward), and sliding them at the same time. Not the easiest manouevre but it's always worked for me.
Mike!
Suffolk
I had to buy a pair of the proper separating pliers to do mine! No amount of squeezing, pushing and pulling would budge it!
the_mikey
I removed a 10 speed KMC quicklink by hand last week when I Mickled the chain, as said above it helps if you squeeze the two sides plates together, then with a little bit of manipulation the two plates can be separated.
Broadside
Fleet, Hants
I always get the missing link meticulously clean with a baby wipe first and then just remove by hand. If there is any crud around the pins it can be enough to stop the side plate pushing in and sliding along.
slowmotion
Quite dreadful
lost somewhere
I can usually get them apart by squeezing the plates together and then sliding but on my new chain I just couldn't get them to budge. I went out and bought some KMC link pliers.
Shut Up Legs
Down Under Member
I use a Wipperman Connex link, and have never had trouble removing or reconnecting it, and it never comes off by itself. Perhaps you could try one of those instead?
Suspect the chain in the video shown above is in fact a 9 speed and not the more troublesome 10 speed. The 9 speed ones are easy to release by hand.
The KMC 10 speed quick link seems to be a more stubborn beast often requiring more cunning methods to remove.
Thought I would post a video of one easy way to release the link at the roadside with the minimum of stress:
View: https://www.youtube.com/watch?v=iztxyrnOyyU
I make my own tool out of part of a spoke - bend in half and then half way down each side bend a U shaped section which connect with the link leaving two protruding stalks which can be pinched together whilst also squeezing the plates together.
