Kinesis Maxlight FF29 build
C
Crackle
I would be interested in the built up weight as well Cracks, when you get a chance to pop it on the scales. Looking really good.
I will do when I get some decent scales but it's around 11-11.5kg which is what all the individual components added up to when I weighed them and that seems right if I'm comparing it to my steel roadbike but I'll get hold of some scales to double check.
Edit: maybe up that to 11.5-12kg, forgot the pedals.
dan_bo
How much does it cost to Oldham?
Well smart. That bottom pics' ace.
dan_bo
I was waiting for someone to say that ^_^
I can't look at it without thinking of Poirot.
C
Crackle
So today I managed to steal three hours to snaffle a ride at Llandegla. Plan was to do the blue route because I wanted an easy test of the bike so I could get used to it and in case of a build dogtastrophe occuring halfway and because I had only enough time to do that and quick loop of the skills area before needing to be back. It all went swimmingly to plan up until I locked my keys in the car then the day went a bit excrement shaped....
So, never mind that, how did the bike ride: it's definitely a first impressions post this, I 'll need a few more rides before man and machine are one. I didn't start too well with the front wheel sliding a bit on the gravel bends which made me a bit cautious until I remembered I'd left 40psi in both tyres. I left it like that until I got to the top of the climb and then I stopped and let some air out front and back, which was bit guesstastic but...
I set off down and felt reasonably comfortable with the position. I wasn't quite at one with the bike and was scrubbing speed off too much before bends and obstacles, one of the reasons I picked the blue but I managed to get a few sections right and that felt good. Bike feels very tight and quick, needing little input, certainly not ponderous, in fact I forgot it was a 29er. The back end is stiff though, get the position on the bike wrong and the back skits, especially under braking. I need to keep more weight back than I usually do. I might yet change tyres on the back because of that, I'll see.
I also let a bit more air out the front and that seemed to improve things but the sliding was still fresh in my mind and I'll need some time to find the limits of this bike and tyres so didn't really push it. Front suspension is plush. I still actually had feeling in my hands when I finished.
One of the things I was unsure of was getting the bike up off the ground ( I speak here in terms of my limited abilities). I needn't have worried. I managed a few little airs off humps without any difficulty and though there's no real need on the blue, could easily pull a manual, both things much easier than on my old Marin.
In the skills area, the forks easily absorbed the drop offs in comfort. There's a couple of short steep climbs there and I felt the front end lift a bit on them, I'll have to try more to see if I need to alter the stack height.
That was all I took from today, I'll start to fill in the gaps on other rides. So far though, I reckon this is going to suit me once I get more used to it.
Oh, I checked the pressures when I got back. 20 in the front and 25 back, that surprised me. My old Velociraptors would have been flat at those pressures. I'll start at around 30 next time.
Here's the ride
http://app.strava.com/activities/95204148
C
Crackle
Done a few more rides now, not as much as i'd hoped but a knee problem may see me using the bike more and dropping the running so...
No real changes yet. I've two Nobby Nics on now and that's improved the back end skitting. The Nics still squirm in mud but they clean well and the don't slip when you're transitioning off a bank.
I'll move the bars down another spacer as it's too easy to lift the front end and I might change the bars as these just don't look right no matter what position I put them in.
I can't compare the suspension because previously I didn't have any but having some means I can concentrate on other things besides avoiding bumps. Uphill bumps no longer need a huge wrench to get the front over, the suspension just takes it.
Things finally need a tune up now and I've got some oscillation when braking coming from the front, not yet sure what's causing that.
