HJ
Cycling in Scotland
- Auld Reekie
Randochap said:120 psi is a tad high. This actually may be your problem.
Not if they are racing tires...
Hairy Jock said:Not if they are racing tires...
Bought a hybrid a while bk for a 18mile round trip to and from work ...
, it says max pressure 120psi on the tyres, and I just pump them up to that, because I dont want the bumps to have an affect puncture wise, the last puncture was a pinch i think but dont know about the others.Randochap said:From the OP:
So what's the chance they're racing tyres?
That's weird. A pinch flat is when the tyre is forced out sideways so far that the tube is pushed against the inside of the rim. I don't see how you can have that happening if you really do have 120 psi in there - it only ever happened to me before I got a track pump, when I was running tubes at 75-80 psi.CycleChris said:it says max pressure 120psi on the tyres, and I just pump them up to that..... the last puncture was a pinch i think but dont know about the others.
Hairy Jock said:You were saying??
Ianesque said:I had the same problem. So my advice is to check, check and treble check your tyre!!
threefingerjoe said:Tip: When checking the tyre for the cause of the puncture, avoid the temptation to run your fingers around the inside of the tyre. On the first check, use your hanky, or a rag. You'll feel it snag on the thorn, nail, glass, or whatever. If it's so small that you don't find it on the first check, only then go back very carefully and look and feel for something.
Once, while repairing a puncture in the dark, I cut my finger on a piece of glass. After that, everything felt sticky...my pump, my headlamp (that I had removed and was using as a torch), the wheels... When I got to work and saw the bike in the light, it looked as if an axe-murder had taken place!
