Doobiesis
- Poole Dorset
And there's your answer. Problem solved. You enjoyed the ride so stick with them and keep cycling.
I'm gonna try the SPDs again in a few weeks
Don't set yourself a date or allow others to pressurise you into setting one. It's when you feel comfortable with the bike and how it and you react in various road conditions.
That's exactly it. There was a complete load of old borlax 'experiment' carried out by an SPD refusenik cycle journo type, doing the rounds a while back. The advantages of SPD on the actual road, are obvious. If there was no difference, the Pro teams wouldn't bother using SPDs. They do, you do the maths.
I'm gonna try the SPDs again in a few weeks![]()
Except she would need different shoes as hers are 3 hole spd-sl road shoes
Hi Doobiesis, Agree with some of the other contributors to this thread, that it is perhaps a good idea to ride with flat pedals for a while to get your confidence back. After all, cycling is supposed to be a leisure activity, not a chore and certainly not something to cause you anxiety.Thanks for all your replies, I will carry on with the road bike for a few months and I will try again with clips as they cost me a lot! I'd rather be clipped in as when I have managed a ride with them I flew!
I got to the point I was very confident on my hybrid and guessed it would just carry over. Big learning curve for me.![]()
Although I think this has been mentioned previously in your postThe main reason pro teams use clipless is because they ride at such high cadence if they weren't clipped in, the rider's feet would fly off the pedals.
Some people just don't get on with clipless pedals and there is no shame in that. However i would recommend that you persevere a little longer (perhaps find an empty carpark and go round that practicing clipping out and in - it wont be the most interesting of rides but it will help get you used to the action). It's one of those things that once you learn to do becomes so much easier simply because you no longer have to think about doing it.
That's just wrong - a pro riders cadence is not remarkably different to that of an amateur.
I wouldn't claim that the legs generate more power just because your feet are clipped in. But there is no denying that a decent pair of cycling shoes, which obviously, are most commonly used in combination with clipless pedals, will give you a more efficient transfer of any power your legs do generate to the bike. The soles of trainers and other similar footwear will deflect over the pedal when force is applied, effectively sucking some of that energy out of the pedal stroke. Stiff soled cycle shoes, obviously, are designed to if not eliminate, but certainly to minimise this loss.OK, so where does the extra power from clipless come from?
If I fit clipless to my bike, does it make my legs any stronger?
Of course not.
So perhaps clipless gives extra power by pulling up on the down pedal.
That doesn't stand up to scrutiny either.
Given the amount of grunt pushing down on the pedal gives, pulling up with the other leg will not add significantly to the power or momentum of the pedal revolution.
Another thing to consider is the power of your leg.
You have lots of power pushing down, but very little lifting up - I could rest my hand on your instep on the ground and you couldn't lift your foot.
What you could do is kick forward - good power there - but it doesn't help in a cycling application.
I accept being clipped in will produce a tiny amount of extra power which could make half a wheel's difference to Froomey in a sprint finish.
Critical for him - it's the difference between winning and losing.
But it's barely measurable for the rest of us.
As I said, that's not to say no amateur should use clipless.
Clipless is a good solution for any rider who has problems with feet flying off the pedals.
Lots of riders like the feel of being connected to the bike, we all cycle more efficiently when we are happiest, so that's another reason to use clipless.
http://www.specialized.com/gb/gb/ftr/shoes/womens-road-shoes/zante-womens
