Drago
- Suburban Poshshire
[QUOTE 4667282, member: 9609"]my jockeys have never squeaked![/QUOTE]Mine did after they came out of the hot wash. Rubbed me raw they did.
He also need a new saddleYou should buy that bike some decent hoods and bar tape and not worry about your jockeys squeaking.
they're sealed roller bearing
My ninjas needed replacing (see image; includes relatively new one for comparison). I suspect that they were the originals (ie with the 105 RD) so had about 20,000km on them.I replace them with every chain and cassette change,
CTFUNo way, you had to replace them. I'm shocked, really I am, they look fine
I do think those jockey wheel screw threads merit locktite use, each time. Single point of failure and quite difficult to find a jury rig that'd get you far.I removed and replaced the retaining bolts they are now going to fall out
Very true, you’ll end up with a wierd single speed rig, at best.I do think those jockey wheel screw threads merit locktite use, each time. Single point of failure and quite difficult to find a jury rig that'd get you far.
He's seen the light and brought a Brooks,He also need a new saddle![]()
I wouldn't lose much sleep over it TBH. In all my time I have never known them to be loose, never mind drop out. Obviously if they do it is a big issue but provided they are tightened up sufficiently when installed they shouldn't work loose. Having said that, I am not one of those who has to fiddle and remove them every 5 minutes! Even my abused commuter that does around 3kpa in all weather will only get the jockey wheels serviced every year or two and this is enough, don't fix what ain't broken!Doable, probably, as I carry a chain tool. But no fun at all. Off to purchase locktite.
I have some that look a bit like your sharp ones, from a quality mech been used on 2 bikes for about 15 years I suppose. I too am not aware of any particular in use problems but just feel that it surely can't be good for the chain and general drive train to have sharp jockey wheels so different from the new ones. Otherwise god/mr shimano would have made them that way to start with?CTFU
They seemed to work fine too, but I'd have had to clean them, yet again. And when I took them off to do so, I 'nearly' cut my finger on one. New ones seemed 'easier' and the LBS is just down the hill (and has a trueing jig I've used in situ recently to finish off a rim relacing).
