standard wd 40 cleaned the gunk
I never use it under my armpits though
So instead of using chain degreaser to clean the chain, can I use WD40 to clean it then lube it with normal chain oil?
What's all this chain cleaning malarky, next you'll be suggesting you wash your bikes, Pah twaddle
I run all my bike and trike on WD40 have done for years, I get 6500 + miles out of each chain more on my trike.
The only draw back you need to spray on on every 4 - 5 days.
No disrespect to your experience intended, genuinely..
While I was cycling / commuting regularly (100 -120 miles a week) I tried many lubes, regimes, always monitoring each chain life achieved, WD40 included.
Pros...supremely clean chain. Very smooth and quiet transmission when just 9applied. It was relatively cheap then.
Cons..my chain didn't last as long as it would using oil (I'd usually get 1200 to 1600 miles per chain, 9 or 10 speed) with WD I got less than 1000
Constant re application was necessary. It would seem very expensive to do now compared to oil.
I stopped, mainly because I thought it environmentally bad, aerosols propellants aren't good in general, I was using a can maybe every two weeks to keep the chain lubed satisfactorily.
Its strange how to people get such widely different results which just goes to show...if you want to try something, do and make your mind up on your results because there may be quite different circumstances that influence the outcome.
Confirmation bias is a real thing.![]()
