Hi all,
I’m aware that there are some very strong views on lube out there but I thought I would go ahead and poke the bear as this does bother me!
In short, WD40 seems to make my gear train run much better than my MuckAway dry lube, and I was wondering if anyone could explain/ offer advice?
The longer story is, I commute about 100miles a week and so keep my bike reasonably well looked after. Clean the chain and relube with dry lube about once a week (but switch to wet lube during the Winter). Anyway my drive chain was starting to make a little noise, gears were trimmed but the noise was from rear derailleur somewhere could never figure it out. But then I got caught in the rain, loads of surface water and this stripped all of the lube. When I got home I forgot to relube so when I went to work the next day my bike was making loads of noise. At work I found some WD40 which I applied liberally and on my ride home the bike was so quiet, dream like! The other pre-rain noise had gone!
So my question is why? Is WD40 as good (better?) than dry lube? I’m guessing WD40 will disappear much quicker, but for the peace when riding I don’t mind reapplying more often.
Thanks in advance for any words of wisdom.
