Nice bike! Don't over-think it, you'll quickly get used to leaning it slightly to get on or off... just ride it lots! Oh, and drop that stem a couple of inches eh?!
You mean the handle bars?
No he means the vertical bit in the middle. Leave it alone and just ride it. One you've been using the bike for a few months, if you then fancy something a bit quicker, or more rugged then change or get another bike.
Well as much as I’d like that I’m not exactly rich unfortunately.
Yes ! It does look like they are a bit high . Check to see if they aren't too far out of the frame ? There should limit marks stamped into the stem stating a height which they shouldn't go beyond .You mean the handle bars?
It may be fine . It is just that another member pointed it out which made me also question it . There should be a line engraved on the stem which you shouldn't go beyond . There is a bolt on top of the stem which you loosen and then tap downwards in order to loosen the expander. That is if you need to lower it .Thanks I will look. It felt ok to ride it.
In the first picture the OP is not on the saddle - I think the issue is that even when he is not on the saddle there is not much room - as I said earlier in the thread I had a frame of similar size in relation to the family jewels, and it was fine, but a little unsettling on occasion.I cant touch the floor if im sat on any of my bikes, that looks fine
What are you going to use it for, just riding or a specific task, commuting, touring etc...it might have a bearing on how you set the bike up in terms of reach and bar height. You don't need to stick with those bars or stem and changing those things will have an impact on position, comfort and even speed.
For example I had a bike with similar bars which I gave to my son. We changed the bars to straight bars, lower with a longer stem, giving him a more aggressive and streamlined position for commuting, also narrower for weaving through traffic.
There's a lot you can change on a bike to suit you better but ride it first and consider it all.
