Andy in Germany
- Rottenburg am Neckar
I recall seeing a lot of cyclists over the years only wearing cycling caps.
Where I live It's generally considered polite to wear other clothes as well.
First part no, they don't. It also appears to be the heavy end for cycling helmets.But they don't strap that weight on their head!
1lb on the head.
Cycling should be what you want it to beI don't wear either, and nor do I dress up in Lycra. Cycling is, or should be, an everyday casual activity.
You said it was a camelbak, which I understood as a type of drinks bag. What are you drinking that won't deform (or burst) on impact?Second part, why? That weight won't want to deform on impact, is close to the spine, and can easily slide up the back up into the base of the skull.
It's just as likely to get caught, snag on something, twisting you round.
I think that's the speed (12mph) your bonce achieves when falling from that height.
Do you really think manufacturers would build helmets which significantly exceed this standard. If they did, do you not think they would blab about that in their advertising ?
Serious brain injuries on a bike are almost vanishingly rare already.
Neglecting air resistance, an object falling a height of one metre, starting at rest, would be travelling at 10mph when it hit the ground. Your head is twice as high on a bike. 12mph is probably an arbitrary number, and a compromise between safety and making something light and attractive enough for people to buy.
EN1078 is a pretty weak standard anyway. Snell B.90 was supposed to be a lot better but AFAIK no modern helmets comply.
No doubt helped by use of helmets.
So I assume you wear head-protection 24x7? Your choice, doesn't bother me ...Why the focus on severe brain injuries? Personally I'm happy to have a reduction in non-severe brain injuries. It's not a magic space capsule.
One of the difficulties in working with mild brain injuries is that it's often very difficult to attribute them to a particular event, as the injury may only be diagnosed much later. So it's more reliable to look at the severe injuries.Why the focus on severe brain injuries? Personally I'm happy to have a reduction in non-severe brain injuries. It's not a magic space capsule.
Prove it.The important thing is that companies are working to make helmets better and better - hence the new wavecel / MIPS helmets which are quite expensive but offer far more protection than a standard helmet.
That doesn't seem correct. We can do representative surveys of the cycling populaton (the census travel to work is one) and measure who isn't injured at all and what cycling equipment they use. (You can't only ask about helmet use, else you pollute the pool for future surveys.)One of the difficulties in working out the relationship between injury and cycle helmet wearing is that if you aren't injured you don't get counted.So you can only measure events where there was an injury.
Or rather, it's a review not a study and it finds that correlation WHEN crashed. The "reduced odds" is a comparison against crashing the same without a helmet. It does not seem to even consider correlations between crashing or severity of crash and using a cycle helmet, so its later claim "These results support the use of strategies to increase the uptake of bicycle helmets" are unsupported by its evidence.Just one study that finds a correlation between reduction in injury and wearing a cycle helmet.
academic.oup.com/ije/article/46/1/278/2617198
We're back at @boydj's points 4 and 5 again. Using the powers of critical thinking bestowed on him by Human Factors Ltd and having read "as much of the research as he could find on cycle helmets", the best evidence he could come up with was fatally flawed and didn't stand up to even the slightest scrutiny. I'd go as far as saying it was completely pointless.
He was in the 95th percentile too, so he's basically the 'top gun' of critical thinkers. Do you think you can do better?
