Is there a shim to convert a 31.8mm front mech clamp for use on a 28.6mm tube?
Cyclopathic
Leicester.
Before I start stripping one frame of all it's lovely, if a bit old 105 gear and putting it on my lovely, if even older 531 frame I want to know I don't have to go and find a new front mech for the sake of a measly 1.2millimeters.
Deleted member 23692
Cyclopathic
Cyclopathic
Leicester.
Cut up a coke can and layer to the right size, it's good enough for the pro's.
Can't the pros afford the correct size clamp though? Hang on, you mean professional mechanics not professional riders don't you. I just had images of pro riders with bikes held together with soft drink cans.:smile:
Moodyman
Guess you're right Colin, but I've successfully used inner tubes as makeshift shims albeit, not for dérailleur clamp.
stevede
I have a Shimano one I took off my mountain bike when I upgraded the frame and have no use for.
I'll put a picture up but if it's the right thing, cover the postage and it's yours.
Edit: these look like the ones I have with a plastic retainer also http://www.ebay.co.uk/itm/300632471548
Regards
Steve
stevede
Regards
Steve
Found them in the tool box (can't find the plastic bits) - No photo as they are exactly like the ones in the ebay link. Let me know if you want 'em
Cheers
Steve
fossala
Cornwall
I love that the industry calls them 28.6mm, 31.8mm and 34.9mm when they always were, and remain, imperial tube dimensions.
I'm 24 so I may be being dumb but.
28.6 millimetres = 1.12598425 inches
31.8 millimetres = 1.2519685 inches
34.9 millimetres = 1.37401575 inches
Makes even less sense...
