Iain G
yes she's a heavy girl 60kg+ I think it's hard going up hills but fun going down thoughAwesome! Is it heavy? Sorry for taking you off topic
Not necessarily. Looking at the Schwalbe size charts there seem to be at least 2 versions of 22" which are different enough that they are likely to cause problems fitting if you get the wrong one.will most tyres fit if there the same inch diameter like in my case 22"? As you can tell I'm a novice in all aspects of cycling sorry for any questions that seem silly
This is a difficult one now. The Marathon Plus I linked to is available as 25-489 (width-diameter) which is quite a bit narrower than what you have now and slightly bigger in diameter (5mm bigger), which may not seat correctly on your rims.one or the numbers I got someone to jot down off the sidewall was 44-484
What a great idea!You might like to consider cycle breakdown cover from the ETA: https://www.eta.co.uk/breakdown/bicycle/
My insurance with Cycleguard has breakdown cover but unfortunately it doesn't cover flat tyres I have no use in either hands too (typing with feet) so I need to see if I can stick a waterproof mobile phone any where on my Trike that is accessible to me & I'm able to use (if there's waterproof mobile phones available). That cover would be great & so cheap too thanks for the help guys
