presta
There's plenty of roads to ride on, but I don't see many cyclists.I agree about Essex. Even though i live in South Essex which is quite urban i have only got to go 10-15 minutes and i'm cycling down quiet leafy lanes.
Not many midweek but more at the weekend especially clubs.There's plenty of roads to ride on, but I don't see many cyclists.
Is that a lot for an Audax in Nov? It sounds like a lot to me. But I'm only a dabbler in Audax and haven't actually done one for a couple of years now.
The only occasions I've been south of a Brentwood-Billericay-Wickford-Crouch line is to get to and from Kent via the T/G ferry. Sahfend would have been on the agenda if there was a ferry at Fambridge, but crossing via the A130 at Battlesbridge was a bit less appealing
Yes you can avoid the horrible A130/A12 junction by going through Butts Green and then up Hammond Road to Boreham.Nice route which i do often when i cycle over to my son's in cressing via Terling,Fairsted and Black NotleyIt's much easier to cross at the A130 junction now, there is a cycle path that takes you round this notorious junction, but even then ,it's sometimes best to go with the flow around the junction, depending non which way your going, it's a bit like Salmon leaping to round sometimes, but once across it a decent cycleway will take you to Chelmsford most of the way, then dumps you at Howes Green, the junction with the A130 & the A12, there isn't a way through it as far as I know, not much good anycase as it dumps you on another fast dual carriageway.
You can avoid it, by doing Baddow/ or Sandon, but not ideal , but cross the Crouch ,then Essex opens up once your clear of Chelmsford, i know my county pretty well, tho not done much that way since my incident.
Essex is a large county, and has many pleasant villages, perhaps why you don't see many cyclist.
Yes only one ride so may well have been a blip but must admit my area is not cyclist friendly at all. From my time before I could do 50 miles out in the deepest darkest parts of Essex with not many incidents at all but as soon as I cross back over the Turnpike idiots encountered per 100metres increases twenty fold.
Without giving away my exact location Rayleigh/Eastwood/Hockley and Wickford are my closest areas so I have Canewdon/Paglesham/Stambridge or across the Turnpike and out to Hanningfield etc.
Hanningfield and the surrounding area is usually quite busy with cyclists. Some lovely cycling around there. But as Ming quite rightly says. The lanes can easily swallow up people. YOU may not see many other whilst cycling, but stop at the Cafe at the reservoir and you'll see plenty pass by.
