swee'pea99
The only true way to say if a battery is ok, is to do a load test, putting the battery under heavy load. It should be able to put out nearly the cold cranking amps(CCA-written on battery)) for a short period.
However a battery that stays above 12.6V for a long period would be a good indication of being good. The battery will fall away from above 13V because that is peak voltage charge. Nominal is 12.6V. If its still above 12.6V for a few days and it spins the engine over quickly when you re install it-good battery.
Sluggish turnover indicates worn battery.
Be very careful when measuring inline current with a simple meter that requires correct lead position for low amperage readings. Cars can draw several amps for a short period whilst going into sleep mode. If you have you meter set on the wrong scale it could either blow a fuse(in the meter) or fry the meter.
Never test in line current when the car is running or about to be started, many, many tens to hundreds of Amps can be drawn and will literally set your little meter on fire.
The only way to measure high Amps safely is to use an Amp clamp.
Thanks, that's really helpful. Not least this
If it's dropping, as it appears to be, by about 0.1 a day, it should be 12.6+ for a week, give or take. I was about to add that I know from experience it'll set the engine spinning at first use, but of course I always top it up fully before re-installing it, so that doesn't really tell me anything. But with the volts holding above 13 after a couple of days, I'm thinking the battery probably is sound.
I take on board the perils of measuring inline current. Which hole & setting would you recommend? As I think I said earlier, I just started off with one far too high then worked my way down till I found one that gave a reading, then stopped. (As best I remember, I wasn't getting even a flicker using the other 'ole...but I could be mistaken. I confuse myself, and forget things a lot.
