LondonCommuter
I'm thinking of buying some for cleaning the frame and drivetrain. Is it any good, or am I better off with soap/water and paraffin, respectively? NB I'm not planning to use it as a lube
LondonCommuter said:I'm thinking of buying some for cleaning the frame and drivetrain. Is it any good, or am I better off with soap/water and paraffin, respectively? NB I'm not planning to use it as a lube
simoncc said:Oil, such as 3 in 1 or a cheaper equivalent is best for cables and chains
nilling said:3 in 1 is a vegetable oil and will turn turn into big thick glup on the chain. It is best avoided even if it is cheap...
tyred said:3 in 1 will turn to gunge in time. I know because my uncle repairs clocks and he says using 3 in 1 to oil a clock is a common mistake people make. It will work at the time, but within a year, it will turn to a sticky gunge and stop the clock from working.
tundragumski said:It's not just another form of WD40! WD40 is water based whereas GT85 is not.
