Is anybody here a Gas heating engineer?
Wardrobes Spazdex, fully fitted wardrobes.
Globalti
DON'T go sawing and lifting floorboards all over the place until you have eliminated other possible faults as you will probably saw through a pipe and cause even more expense. Expanding pipes are a regular but diminishing crack crack crack, certainly not a loud banging, which only happens for a few minutes as the water temnperature increases and the pipes expand. If it is happening all the time it's some kind of airlock problem, which can be very hard to cure.
Rather than ask on here, go and post your question on www.DIYnot.com in the plumbing forum. Be sure to start by describing the system, what kind of boiler, etc etc or they will be rude instead of helpful. But there are some plumbers running that forum who genuinely enjoy this kind of challenge.
Clearly sawing through a pipe is not a good thing, but circular saws have depth adjustment. Lifting floor boards is a peice of pish for anyone with a modicum of DIY ability.
The expanding pipe in my bathroom floor made a godawful banging sound, as if it was being belted with a hammer. It kept everyone in the house awake as it was aplified by the floorspace and easily cured by fitting felt under the pipe.
Certainly good advice to go on a DIY forum but under the circumstances, without having someone actually inspect the system in person, the advice of one plumber (me) is as good as the next.
Dont know how much plumbers cost in your area (if you can even find one) but I reckon a couple of hours lifting floor boards might save BTFB several hundred quid.
I have also known banging to be caused by the pump vibrating through the pipes. Bracing the pipes around the pump might be worth a try first?
