Is a torque wrench really necessary ?
Adam4868
Neat job.
I take it there's no room to knock the cabinet sideways.
Yes it's tight against a pillar.Im sure you could still take it,but it's take a bit more time and brute force.
Pale Rider
We used to use a arc welder for initials on our tools.
I never liked those things - I was scared of electrocuting myself.
Which tells you I don't understand arc welding.
A gas torch was my welding limit, and I was never much good with one of those.
Adam4868
Can't tell you the amount of times as apprentice where someone would give me a shock with one.Usually by touching the metal bench id be working.on !
Pale Rider
I did use the spot welder a few times for attaching things such as car wings.
At the time, an innovation was continuous wire welding - you could see the little wire tag end in the weld.
From memory, we didn't have one of those machines.
Probably too expensive.
Adam4868
Many moons ago I did a appenteship in sheetmetal/welding.So it was mostly arc,oxy accet and Tig.Never used mig then,but I've had a few goes since in garages.Im well out of that game now,we used to make.some great bespoke stuff in stainless and always enjoyed Tig welding.
Pale Rider
I didn't know that mig welding is another name for continuous wire welding.
I had the impression that mig was more used by car manufacturers than garages.
The plain welding wire used in oxy acetylene had lots of other uses.
I've bodged a few exhausts with it on motorway breakdowns, and I made a bowl oil filter seal removing tool from the thicker gauge version.
Always kept a few lengths in the toolbox.
Adam4868
Oh I don't know,was presuming you meant mig.Most car garages,body shop will use mig nowadays.Its wire fed on a spool.Its easy for thin metals like car repair and tack welding.
keithmac
I welded a Ford Transit Minibus over Christmas.
Used gasless mig wire for first time and was very happy with the results (so was MOT tester!).
Gas mig welding outside is a pain, and gas is expensive if you don't use it all that often (bottle rental was £80 a year iirc).
Rebuilt both front inner wings, rear chassis rail, rear sill and rear inner arches. It was pretty bad when you started poking at it!.
Made repair panels out of 2mm sheet steel, managed to buy a sill.
